Hello everyone I'm new here
But having recently got back into photography after a few years away I
See how things have moved on, still after finding a reasonable priced A68
I would like to know what is the best free photo editing software for editing
In both jpeg and raw? I used to use Adobe photo shop but I'm sure things have
Moved on.
Hi @Taz634
The adobe software applications quite probably are the most used today. There is also free software from Sony, Imaging Edge Desktop, but it will not be as comprehensive.
I think of two options for raw editing free software,
Darktable (https://www.darktable.org/install/), and
RawTherapee (https://rawtherapee.com/). Both are similar.
For manipulating images, JPEG, PNG, TIFF, etc, there is
GIMP (https://www.gimp.org/).
It also uses a plugin from darktable or RawTherapee which can open raw images as well.
All three are free and can be installed on Linux, macOS or Windows.
I hope they will help.
I am sorry for the odd formatting. The page keeps giving this error: which is not permitted in this community. Please remove this content before sending your post.
