First seen with A6700. Downloaded a few images to tablet with wifi / Bluetooth, then switched camera off. Next morning found A6700 had completely flat battery. Another time downloaded some images to tablet, switched off, after an hour or so found A6700 battery compartment warm.
Now updated A1 and now uses Creators App. Downloaded a few images to tablet with WiFi / Bluetooth, then Switched camera off. Next day found A1 with completely flat battery.
It appears cameras are not switching off ?.
Anyone else seen similar?
Like OP, I have also 3 batteries, it happens whatever the battery…
I will not factory reset the camera as it is useless for me with the standard settings and I have no time to play.
Yes, tried a reset and tried 3 batteries... nothing makes any difference...
Hey @Arn4ud
The link for settings file that you've posted seems to be expired. Can you upload it again, please?
I have downloaded and installed v2.02 to the A1 and so far l haven't seen the camera not been able to switch on after a download with the Creators App. Was there anything in the update for this issue ?
Only used it for a short while so l'll see how it goes....
Still not fixed, sometimes needs camera battery removing to get it to switch on again.
Done....
