Hi All,
I'd like to propose a feature request. Digital ND Gradient filter. This can be achieved by using different sensitivity on different pixels of the matrix gradualy increasing line-by-line. So in case of difficult lighting conditions bright areas (e.g. sky) can be pictured with lower ISO, while other areas with higher.
Current implementation of HDR/DRO does not work for me, since I don't have control over the area of effect.
Thanks.
Hi there,
Why not use the ND grad feature in Adobe camera raw?
I use it on most of my landscape shots as it gives a huge amount of flexibilty in terms of where you want the graduation line to be, the brightness/darkness, colour saturation etc.
Martin
