I am running my DPF-D72N picture frame off of a Compact Flash card (SanDisk Ultra II 15MB/s 2GB) with about 1900 pictures, sorted into 19 folders of 99 pictures each (pictures are all JPG/JPEG format). When I run a Slide Show, the picture frame cycles through all the pictures once, and then stops. The only way I can restart the slide show is to power the frame off and back on, and then it stops again after displaying all the pictures one time. I used to be able to get the slide show to run continuously, but now for some reason it will only run once. Help!
Hello scolburn - Welcome to the Sony Forums
Other than resetting the frame back to its factory defaults, have you tried using a PC to reorganise the files into a single folder to see if this helps?
Thanks,
Simon
