Please can someone give me a straight answer to the following question: How do I connect my Metz 64 AF1 (Sony MI fit) VIA OFF-CAMERA CABLE to my A77ii. Sony seem unwilling to answer this question, notwithstanding that the answer is probably the same as it would be if I used their own HVL F43 flash, that lacks a socket.
Do I need the two off-camera shoes (FA-CS1M) and the multi-flash cable, or can I use the ADP-MAA adaptor, then my existing Minolta cable, into a single FA-CS1M Off-Camera Shoe?
Any assistance will be gratefully received!
Thanks
Phil
Hi Thalamus
Thanks for your reply. I don't actually have the F43 flash, but I tried asking Sony about connecting my Metz 64, which doesn't have a connecting socket but does have the multi-interface foot. They insist they "cannot support" the use of third-party flashes, notwithstanding that their predecessors Minolta were quite happy to advise on how to connect third party studio flash some years ago. Metz guns are famously high-quality and unlikely to cause any problems.
Incidentally, I have downloaded the F43 instructions, and there is no mention of a sync terminal, only the MI foot, hence why I quoted this model. I really would appreciate an answer because I want to buy the connectors as soon as possible.
Thanks again,
Phil Lewin.
