I tried to register my A850 but it’s not in the list, the A900 isn’t there either? How do I talk to Sony to get it sorted?
Hey @timbaldw
Can you try to type it as "DSLR-A850" and check again? That's if you're speaking about MySony of course.
Thanks for your reply - Yes im talking about my Sony. If you go to register new product and type in DSLR-A850 its not there neither is A900 guess its been missed off. I also followed all the options - find my product etc. No luck.
Guess it needs action from Sony
Hey @timbaldw, I think that you need to confirm that you have the correct model as written on the camera as you can check it as mentioned here. Also, you can try using a different device and a different browser as it might be a glitching. if this didn't help i think contacting Sony Support is going to be the next step.
