I contacted Sony via FB looking for pre sales recommendations and they sent me here!!!!!!
I am currently planning a photographic projects which will see me working in some challenging environments and weather conditions over a period of 3 years. As a result I am looking for a camera system that is robust, reliable will allow me to work in the field seamlessly.
I would be grateful if you could recommend from your range a system using the following requirements.
If you have any questions please do not hesitate to contact me.
Kind regards
Simon
Camera system's working environment:
High Street
Industrial
Land / Sea Scapes
Churches Interiors and Exteriors.
All weathers
All seasons
Indoors with available light only. (No flash)
Camera System Equipment required:
2/3 x lenses as per the specifications below.
2 x Camera bodies as per the specifications below.
Camera system requirements
Essential
Lens focal length range of 16mm – 200mm (35mm Full Frame equiv) split over two / three lenses.
Lens maximum aperture of F4.
Weather Sealed and dust proof camera body and lenses.
20 megapixel sensor or greater.
Image Stabilisation on Camera / and or Lens.
Ability to capture and produce clean images up to ISO 3200 at a minimum.
Ability to customize dials for exposure compensation and aperture control.
Ability to bracket 3/5 exposures from 0.7 to 1.5 of a stop.
Ability to capture RAW.
Metering options: Multi-segment, Centre-weighted, and Spot.
Nice to have but must not compromise Essential requirements
Dual memory card slots.
Electronic Shutter Options
In camera focus stacking / bracketing.
Manual Focus Peaking.
Depth of field preview.
I am aware of the independent reviews I am looking for Sony's recommendations specifically.
Si
