Hi Can anyone recommend a video showing how to set assign a custom button for birds in flight for the A6500? Thanks
@ZumbaQ1907, I think it would be hard to find a video that specific, did you try to follow these settings Custom Key(Shoot.)/Custom Key(PB) and from there you can set your favourable function.
Thank you
