doesn't the animal auto focus work with this kind of shots?
I think the R3 with 30 fps will do better than your A9II
Subjects moving towards you in the frame are the trickiest ones for any camera
In terms of settings you can push sensitivity to the max and frame rate to 20fps and hope for the best
