Is there any more information on this?
I've just updated my A77 to v1.07 and I have the same lens. I'll put a circ polariser on it and give it a go to see what happens.
hello, I have tried the same polariser and lens on my A900 without issues so I can only conclude its something to do with the firmware upgrade. I have dozens of shots with the polariser on the A77 and most of my lenses without any problems. It doesn't seem logical to me but I can't think of another reason. If you PM me I can send you a sample of the unsharp photos.
are you getting sharp images without the filter?
have you give the filter a good clean laterly?
hmmm strange, can you get sharp images with manual focus/focus peeking?
after thinking about this and since your on a A77, if you use this lens most of the time with that filter on, have a play with the len micro adjustment options in the camera, and see if that helps.
Kind regards
Mark.
