Hey, did you try changing the password? Restarting the server and the camera as well?
I'd also recommend that you reset network settings: https://helpguide.sony.net/di/ftp_2380/v1/en/contents/network_reset.html
Thanks for replying.i got in touch with Sony Pro support who said when yo put in your password and click save it does save the settings although it still shows reset,they said also that they have got in touch with sony development engineers to see if this can be changed as it is very confusing,let's hope they change it.
@BlackBear1950 try the new ILCE-9M3 System Software (Firmware) Update Ver. 2.00:
https://www.sony.co.uk/electronics/support/e-mount-body-ilce-9-series/ilce-9m3/software/00341216
Just updated firmware,all ok now.
Thanks.
