When using the small focus area, the focus judders in & out. Anybody else with the same problem?
Have you tried resetting the camera to factory settings?
Also, does the issue only happen with small focus area (i.e. changing the settings fixes it)?
You can always use WeTransfer for sharing files, doesn't need any accounts, setup or anything like that.
- JD
Hi gbcegae, have you tried removing the batteries for two minutes and trying again? If the issue persists, it might need repair. I suggest contacting Sony first.
