Is it possible to change/add/delete the A7C ii Touch Function Icons on the screen? I know that the whole column either side can be hidden but I want to customise what icons are shown.
Thanks.
Ok, now I understand.
No, those icons are defined by the firmware https://helpguide.sony.net/ilc/2360/v1/en/contents/221h_touch_function_icon.html
PS: I was reading A7Cii user manual, it's really cool! More than I was thinking. One day I have to trade my A7C for that one!
Actually is really hard to understand exactly what you mean.
The best thing I can think is that
https://helpguide.sony.net/ilc/2360/v1/en/contents/0413_using_function_menu.html
I mean the 2 vertical columns of 'Touch Icons'
Hopefully this can be made customisable in a future firmware upgrade.
There are functions like REC and FOCUS MAP that I just don't want or need on the screen as it's too easy to accidentally select them. Others, like switching the AF mode from SPOT to TRACK on the fly is very handy.
