January 2024
Sony A7C II
Has anyone found a compatible wired remote that plugs into the camera's USB-C port?
Since the A7C II doesn't have a Multi port my existing remote/intervalometer now appears to be obsolete.
I know I can use my mobile phone to trigger the shutter, I've tried it a few times but I find it gimmicky - I much prefer a dedicated remote that's physically attached to the camera so I can manually perform long exposures in Bulb mode (waterfalls, sea, stars etc.)
Either a USB-C remote or an adaptor cable from Multi to USB-C would do.
Thanks for the reply, it looks like wireless is the only option at the moment.
(I've ordered a Smallrig 3902 Bluetooth remote for now, just to see how good/frustrating I find it)
