please help camera did connect to laptop but know when i plug it in usb it say check connection thanks ian
Hi Ian, welcome to the Sony Forums
You don't mention which OS you're using, but it may be that updating your PC has change the way it behaves with your USB connection
Often a quick solution to this kind of problem is to remove the memory card form the camera and use an accessory card reader instead.
Mick
