Why can't / won't Sony re-make the 200mm f2.8 prime lens
Message was edited by: jefwarre0
Hello again,
I have been looking into this and although this lens isn't currently in production, the range of available lenses is based upon overall customer demand and so if there is enough demand for this lens in the marketplace in the future, there is every possibility that it will be re-introduced. It is unfortunately not possible to make a precise prediction about whether or not it will definitely happen.
Thanks
Simon
Hello jefwarre0 - welcome to the Sony Forums
I am running this question by some colleagues / highlighting your forum message to see if we can get you an answer about this lens.
Thanks
Simon
Hello again,
Thanks
Simon
