hi everybody. need some help.. I used my as200 for a first time underwater with the waterproof case in very little depth (10-20cm under sea surface) and it just stop working.. i ve change the battery with a new one and the only thing it does is, it blinks the red light back of the camera.. it blinks with specific order, 2 slow blinks-small pause -6 fast blinks. If someone can help how to fix this..
I try to start it even without sd card.. nothing happens. The screen on the side wont open... Yes it get a little bit of wet...
Hey i am dimispanagio who make this post.. i dont know why sony change my user name. Please if you know how to fix this.
Hello @Dimisr6,
so if it got wet, it might be broken.
Have you charged the battery properly inside the camera? Does the camera even show a light when connecting it to the charging cable? Did you try another charger?
- Nic
I try to charge the cam with another charger and the cam react with the same way. Flashing the light two-six times and then the same again. The charging indicator light does not stay always on as it must be when it charges.
