Hi Guys,
so im looking for a replacement for the sticky pads on the VCT-AM1 mounts, has anyone got any suggestions?
Cheers,
Murray Mint
Hello @Murray_mint,
since those adhesive pads are single use only (by the nature of the adhesive), I generally purchase new pads when I e.g. purchase a new helmet.
You may use the grey double sided tape by 3M, since that is the same adhesive than used on the mounts by default.
- Nic
Great answer Nic and you touch on what im looking for. You mention the 3M tape but finding the right stuff is proving a problem. I have seen that GoPro suggest using 3M 4991 VHB but getting hold of this material in the size of the Sony mount is a problem, what do you use instead?
https://gopro.com/help/articles/how_to/How-to-Purchase-Adhesive-Material-for-Mounts
Hello @Murray_mint,
I use a roll of tape and use two strips next to each other (which covers the width of the adhesive pad) - but then again, you never get the adhesive to adhere to the pad itself as it does when you purchase a new mount - that is why I suggest to rather purchase new adhesive mounts instead of just replacing the adhesive.
- Nic
