Hello
I have been trying to access the Sony Entertainment Network "All Applications" list, which only brings up a few applications unless I leave it loading on the page for 5 minutes where it finally comes up with the entire selection.
Once this has happened, if I try and go on an application such as Netflix, I receive the message "The application is temporarily unavailable. Please try again later". The same happens with other apps such as Sky News etc.
My internet connection is fine and have tried both wired and wireless. I have reset the internet aswell as doing a factory reset and unplugging the television from the wall for 10 minutes.
Could someone please advise me on what I can do to get this working.
Many Thanks
Hi everyone,
Just to let you know that we have referred this issue to Sony who are looking into the problem. We'll try and let you know as soon as we have any new information. Thanks so much for your patience on this Friday afternoon!
Hi Guys,
Bought this tv yesterday, was trying to set it up,I have internet connected etc. When i try to open the Facebook app. It tells me to check my internet connection, but my connection is fine. Anyone had this problem? I only have about 3mb of broadband with Eirocm though. I cant get into sony network at all either
Hi all
Its been almost 16 hours since the original post. With only 3 of you reporting problems, a further 3 more on the AV Forums (around that 7-8pm mark yesterday) and no one on Digital Spy.
I have a KDL-40NX723 (2011) and have not had problems.
It seems that this issue is specific to the W6 model (as far as I can tell) and not wide-spread, as I would have expected a lot more people to report in between the 3 forums.
Are you all still experiencing this problem. If so, are you on the latest firmware for your TV? Have you also tried rebooting your ISP's router?
Hello
I have managed to get Netflix up which has now signed in as apparantly the apps list came up last night (I was out). I accessed Netflix (had app there via history) as I still cannot access the "All Applications List".
My wireless internet - download speed is 22.01 and upload speed is 1.84. My tv however is connect via ethernet cable, so may be faster. However, Netflix is loading at a fast speed so I don´t believe it is an internet speed based problem.
Regards
Is everything working now though?
