When I click the Xperia system update, is it the Android 10 upgrade?
Hi @sundayrequiem,
If you are in the UK, it's most likely the Android 10 update as it was released for two more customizations there about 9 hours ago!
@sundayrequiem wrote:When I click the Xperia system update, is it the Android 10 upgrade?
Check this site :
To finding the " Xperia CAD number "
*#*#7378423#*#*
Tap on "service info"
Then "software info"
and look at "customization version"
Why no Germany/EU yet?
It would seem Vodafone UK haven't got it yet they are so slow!!
@Yekollu and @LanceGoss,
I have no information on how the roll out of software updates work and what the hold up is or when it will be released for all the Xperia 5 versions and customizations.
You will have to wait for the notification pop up in your device and I don't know if this will be tomorrow, next week or the week after that.
