Charging in works also with old Nokia 8.
Xperia 5V fast charging works with home charger Sony UHC-32, and from my PC usb-c power delivery ports - so there is not wrong in cables.
Hi @tos-82, did you try a different cable with the Xperia on your car? Does it still not work? Can you try a different Android phone through the same charger of your Xperia through your car and check if it will work? Also, can you try the same cable on a different car through the Xperia 5V?
Thank you for your help.
I have tested 3 different cables, one of them was sony cable from my old xperia 5 II.
Older android phones will work well, like Nokia 8, Samsung A35 and Xperia 5 II.
Iphone with USB-C will use fast charging on my car.
I tested charging Xperia 5V from vw dealer (Passat 2025, same infotainment system), Settings says not charging.
Im glad that wireless charging is fast enough, but my phone get hot.
I tested also developer mode and other usb settings, no luck.
I think that "no charging" feature came aftet Xperia system update 67.2.A.3.2.
I got the car at 12.3.2025 and Xperia updated itself at 24.3.2025
Update 67.2.A.3.16 came today, it did not fix the problem.
Now it is working.
Sony service wanted that i will reset my phone and use pc companion software via PC. I did not do it, because it is too much for start over.
After some latest updates, charging seems to be working and it say "fast charging".
