xperia 5 II device corrupted
profile.country.DE.title
chellux
New
hi, i got an xperia 5 II
now i cant boot, it says "your device is corrupted and cannot be trusted and will not boot"
pc connect dont work..
device manager dont show anything
its like a expensive black brick.. cant use it for anything -.-
is there any fix for this?
cant reset it or something...
4 REPLIES 4
profile.country.RU.title
Pavel.i
Member
If the computer detects that the phone is connected, you can try to repair the software using the Xperia Companion app
profile.country.NL.title
Strampke
Expert
Go https://www.sony.co.uk/electronics/support/mobile-phones-tablets-mobile-phones/xperia-5-ii/articles/...
Read #5
(If your device cannot be detected or started, or is a Smartwatch 3, then check the box with this information before you get started.)
chellux
New
i tryed it many times. it dont work. it shows an error...
profile.country.GB.title
CosmicTomato
Specialist
if the SD/SIM card is defect in any way, that sure will affect the phone, try the 2 mins restart without them, press and hold on both the volume up and power keys, for 2 whole minutes.
