Hi Everyone,
For the past week, I've been having "1" NEW UNREAD MESSAGE indicated on the SMS/Message Icon App, that won't go away.
I've checked everywhere, I've got no new unread message. I restarted phone, marked all messages "as read" in the Messaging App, but nothing seems to clear this "1" new unread message on the SMS/Message Icon App...
FYI: I tried replying to an existing message thread, typing words in and then deleting it, this doesn't work. I also tried changing my default messaging app to Signal, then re-enabling default SMS App to "Message", this didn't work either.
Can anyone help please providing a verified working solution?
Many thanks!
Hi again!
This doesn't work.
Suggested solution that works: Settings > Apps > Messages App > 3-dots Top Right corner of the screen > Uninstall Updates > Restart Phone.
Then reinstall updates via GooglePlay Store to update the Messages App.
This worked for me, and I trust it will for everyone else who's facing this issue !
Hello @ChamBoy74
can you try to tap on the home screen
tap home settings
tap notifcation dots
try to turn it on and off,
restart your device
also try if you multiple messages, try to scroll down, and check to make sure everything has been read,
Hi Nolramlb!
Thanks for your message.
Unfortunately, suggested solution does not work at all.
As previously mentioned, I did ensure marking all my SMS Messages/What'sApp Messages as "read". I'm sure I've got no unread messages.
This topic's also been raised with Android Google Messages support, but they're saying this is a SONY Xperia Phone related issue... I completely doubt it!
So far, no solution found elsewhere on the web.
Regards.
hello @ChamBoy74
can you try this
restart your device to safe mode by long tapping the power off button.
long tap messeges app
tap on the bottom part with the arrow down
then tap allow notification dot.
restart your device
then do the same steps
this time allow notification dot
Hi again!
This doesn't work.
Hi.
It does not worked for me. Glad to hear that it worked for you.
Hi Soso_M4,
Honestly, this is as far as I can go.
Sorry to hear it's not working for you.
Force Stop "Messages" Android App, clear cache, uninstall it, then restart your phone, finally go back to GooglePlay Store to re-install "Messages" App. It should work.
You can always try Google Apps Help/Support Forums.
Perhaps have you missed a step in the suggested solution?
Hope you'll succeed.
Bye for now.
ChamBoy74
This resolution does not work
This does not work as you can't uninstall the SMS messaging app
