Hi. I've noticed in settings there's possibility to adjust volume for Ring and Notifications together, not separately. Ring volume is good but somehow Notification volume could be a little louder, but in this case I get good ringing and sometimes low notification sound.Am I doing something wrong or there is only mentioned option to adjust ring and notification volume together?
Hello @@MarlonUk1 Changing the sound of notification is the only option left under this circumstances. So yes, I changed the sound for some notifications which I think are a bit louder.
Nevertheless, I think this might be taken in consideration for some future updates - separation of volume for Ring and Notifications.
Hello @apolonian
unfortunately it seems they are coupled together the Ring and Notification volume. have you tried changing the notification sound instead?
