Hey there I have the Xperia 1, as you all know
However; as you also know ,it has SERIOUS stability (OIS) issues at 4K resolution.
Can you assure me that the OIS is sorted out on this model, as surely you arent going to make the SAME mistakes as you did with the Xperia 1?
Given that is the EXACT same camera setup and software then im very very worried!
Its not the same camera setup. Sony has actually lied on that point. Xperia 5 cant do Slo-mo feature, so it misses the Dram to be able to that feature. Somehow SONY think that was a good idea, and still consider Xperia 5's camera setup exactly the same as Xperia 1.
