Am I supposed to download a saperate app or am I missing sth, the circle icon is kind of annoying.
Hi @DeepShip, sorry for the late reply.
You can read more about why themes is not available on the link below.
https://support.sonymobile.com/global-en/xperia5/faq/apps-&-settings/8019307402e887a420165e528f2ae00...
As @eddy_hyde mentioned, you can turn off Xperia loops in Settings > Appearance > Xperia Loops.
@eddy_hyde, thanks for assisting @DeepShip!
I quite like the loops as well, but it's good that there is an option to turn it off if someone doesn't want it!
No your right, bit you can switch loops off in appearance menu. I quite like the loops rhough
