Hello @ForzaDan,
the banding is caused by the frame-rate and power frequency mismatch. If you go into the Cinema Pro app you can adjust the shutter angle manually and counter this issue.
The camera records in 24/30/60 or 120 fps and the power frequency in the UK is 50Hz.
- Nic
Hi Nic, I tried that it makes no difference my two other Samsung Phones do not do this and I don't believe you should have to go into Pro settings to try counter this issue. As I've said I think the Auto mode in low light and HDR mode are terrible, why does it instantly go Dull looking? It doesn't look like any kind of HDR at all. The phone is capable of taking good photos but software is very poor compared to the competition. I am really hoping for updates for improvements.
