Hello!
How can i switch off the Retail Mode on my Xperia 10 Plus 4293?
#sellmore# didn't help..
Hi @Emm23, welcome to our forum!
Since the code doesn't work, go to Settings & notifications > tap the three dots in the top right corner "Show system" > scroll down and find "Retail demo" > tap on it and tap on "Force stop".
If you still aren't able to remove it, could you please send me a private message with your IMEI number? It could be that the device is not meant to be sold and is what we call a Storefront device and you can't remove the Demo mode on these devices, as far as I know.
You can find the IMEI number if you open up the Phone application and type in *#06#, or in Settings > System > About phone.
Let me know if that helps!
Hi @Emm23, thank you.
I can see that the device was originally sold in Hong Kong but someone has rooted it/flashed it and installed the customization for the United Kingdom.
If you didn't do this, get in touch with the seller, or try and go to Settings > Lock screen & Security > Advanced > Device admin apps > remove the check mark next to "Retail demo".
If it still doesn't work, get in touch with the seller.
Ok.
Thank you very much!
I'll ask the reseller jbout it.
My best wishes!
Em
