Anyone know if the Sony Xperia 10 had WiFi calling , cannot find settings to turn it on,, thanks
Hi @Rab-uk and welcome to our community!
Xperia 10 supports Wi-Fi calling and the option can be found if you open up the Phone application > tap the menu button (three vertical dots) > Settings > Calls > Wi-Fi Calling.
Keep in mind that the requirements below has to be fulfilled for you to be able to use this feature.
If you aren't able to find the setting in your device and since the device model supports it in general, get in touch with your operator / service provider and they will be able to provide additional information if they supports it for the specific device, if your subscription supports it and so forth.
I hope that helps!
