Has anyone figured out a way around the lag issue while using a ds4 controller? Works perfectly for 15 - 20 seconds and then goes completely out of sync and lags like crazy.
Iv tried the auto Bluetooth app to no avail.
It's crazy that Sony can't ever support there own products to work with each other, let alone remote play.
Xperia 10
maybe try this:
settings-> system->advanced->reset options->reset network settings
