I have problems with the WiFi connection every day. I think this is not normal. Xperia team fix it please.
Yes I am having the same problema wifi keeps dropping then crashes goes of its not normal at all I think the last update broke it
@Ram131 wrote:I have problems with the WiFi connection every day. I think this is not normal. Xperia team fix it please.
Having WiFi problem for weeks now as well.
My phone works 100% on mobile data/LTE - but as soon as I turn on WiFi the phone freezes and becomes unresponsive - can only reset it - starts up with the 'tool triangle' - then I have to quickly turn off WiFi before it connects - then everything is fine again.. super annoying not to be able to use WiFi....
I've done the latest Pie9 updates (10 not available in our region yet) - ran various hardware diagnostic checks from the Playstore apps (no issues) - cleared the cache for all apps - still doesn't work..
Anybody have a fix for this PLEASE?
These are my setting. I turn off open network notification so it won't endless look for WiFi.
I appreciate the feedback - does resetting the network settings via System delete all your saved networks and mobile access point names and settings?
I did do a restart in Safe Mode and it seems that then the WiFi works fine - turning my suspicions to it being an app that is causing the problem.. but now figuring out which app it is will be difficult..
Only recent one I recall loading before the problem started is TrueCaller - but I can't see how that will cause freezing when turning on WiFi..
