When I am listening to music with my earphones in the music doesn't pause when I receive an incoming call and there is no ringtone sound in my earphones when someone tries to call me. This is probably because my phone call and notifications sound is on silent mode but I want to override this for when earphones are in without having to take the phone off silent mode. Having the phone on vibrate isn't enough as a lot of the time I won't feel the phone go off when it's in my pocket and with music playing there is no indication of when someone is trying to call me. Is there anyway I can change the setting to overcome this?
Hi @STEEZE, let me see if I can help out here.
As you mentioned, if the ringer is set on silent while you listen to music, the playback will not be paused if an incoming call occurs. Sadly there is no setting available in the phone able to overcome this. The only thing that i can advise is to turn on the ringer while listening to music in order to avoid missing incoming calls.
I hope that answered your question.
