Me and my friends with 10 II were facing the following issue: audio sampling is clipping while playback from SoundCloud in browsers. It seems that only in Xperia is this issue and Firefox (the sample below is from Firefox - we are using it only in Xperia, and Firefox won't solve it blaming Sony software)! Please let Sony about this and fix it: https://drive.google.com/file/d/1MrT9y43yrHwF5wgrUALd7m_UaumwQYKv/view
Thank you!
Hey AlexandruRai,
Have you tried to clear the Browser's cached data? ( Settings - Apps & Notifications - Browser - Storage - Clear cache and data )
Also, try to uninstall the Browser's updates by clicking on the vertical dots on the top right corner and select Uninstall Updates, this has sorted a similar issue for me.
Tried everything! Bad Android 11 upgrades are the fault!
Camera still the same... Android 10 was much better overall!
59.1.A.2.169 does nothing...
I assume a software repair via Xperia companion will sort this issue out. Have you tried that?
I did... Solved partially by Firefox but Sony must test these and fix in the first place...
Well, glad to hear that you sorted it out
You can be in touch with the Sony reps directly from here if it happens again.
It's not quite sorted... Sent already... Sony must have here representatives! Best way to see what's going on!
