How do i get wifi calling on an xperia10
Hi @45lemmy let me see if I can help out here.
In order to be able to make calls with Wi-Fi Calling some conditions must be fulfilled:
To enable WiFi-calling, please follow the steps below.
I hope that helped!
Hi I don't seem to have the options you gave me on my xperia10
Thank you for the quick reply, @45lemmy.
In that case I would suggest that you get in contact with your service provider to verify that sthe service providerand subscription (incl. SIM card) supports Wi-Fi Calling for the device model you're using.
