x
Firmware Update Question
SOLVED
5lbsOfPez
Visitor
Hello,
I updated my phone to the most recent firmware, however looking at the update History, it only displays the last firmware update. Which I installed April 6th. If it matters I used the Windows companion app to update. Is there any way to fix this issue?
Also is there anyway I can see what the new firmware adds? I'm still using February security patch. Thanks for any help.
1 ACCEPTED SOLUTION
Accepted Solutions
profile.country.GB.title
Uliwooly
Expert
@Valbunny
That's correct, you can check this unofficial website http://www.xperiablog.net/ they usually report update findings and when they are rolled out in any region.
3 REPLIES 3
Uliwooly
Expert
@Valbunny
minor updates are bug fixes and security updates.
5lbsOfPez
Visitor
I see. So the security updates are only currently on February? Also, it wasn't tracked in I odate history because it was a minor update?
Uliwooly
Expert
@Valbunny
