I would like to use WIFI calling on my SIM free X10 But it does not seem to be available
Oh the good old Xperia X10, it was released in 2010, it has been years since it received any updates, and you need an update to get WiFi calls.
Just wondering, are you asking about the
Xperia X10
or
Xperia 10 / Xperia 10 Plus
Hi
Its an Sony Xperia 10
Thanks
Hi @Dec1962,
Xperia 10 do have support for WiFi-calling. However, In order to be able to make calls with Wi-Fi Calling some conditions must be fulfilled:
If all these requirements are met, You should be able to enable WiFi-calling by opening the phone app > tap the menu icon (three vertical dots) > Settings > Calling accounts > Select a SIM card > Wi-Fi Calling. If Wi-Fi Calling isn't available in this menu, you need to get in contact with your network operator.
I hope that answered your question!
