J'ai mis en place le déverrouillage à l'aide du schéma et je souhaiterais le désactiver
Pouvez vous m'aider
Merci
I set up the unlocking using the schematic and I would like to disable it
Can you help me
Thank you
gt
Hi @Marcelle65, let me see if i can be of any help here!
Your question has been translated to English as this is an International forum, please post any replies in English and it will be easier for me and other users to assist you.
If you want to disable the unlock pattern on your phone you can do this in the device settings. From your home screen, find and tap Settings > Tap Lock screen and security > Tap Screen lock. After confirming your pattern you will be able to choose a screen lock of your choosing. If you want to reed more about screen locks on your Xperia 10, please view this link.
Let me know if that helps and feel free to return if you have further questions!
