just got my new xperia 10vi, i have an issue with Bluetooth, there is no icon (above near wi-fi as usual) when its on as i used to see on other phones. Has anybody experienced this already?
Hello @rufat1,
this is completely normal on newer Android versions. You have to pull down the quick access menu to see the bluetooth status.
- Nic
Hello @rufat1,
- Nic
