I'm not sure if it's the tallness of the phone or the software but sometimes the phone just doesn't go into landscape mode no matter how I turn it, it happens alot while watching videos especially prime video, but can happen with chrome and other apps.
(Also it would be of great help if split screen allowed videos to be playing in landscape which as far as I can tell is impossible).
Thanks for advice, this is the only action to force screen to rotate after system update to 53.0.A.14.47 (simple restart doesn't help)
I have the same during ~1 week, restarting, save mode not helped... I don't know what the problem is, but I found some interesting thing, that shouldn't be by 40 m/s2 in straight vertical orientation (it must be 0.0)
