All of the following problems are based on feedback from users in mainland China. No matter where we are, we are loyal followers of Sony Xperia phones. You should not ignore us.
1.Xperia Transfer Mobile can't transfer old phone data: because Google is not available in mainland China, we have to use this feature to transfer data from old phones, but Xperia 1 has removed this feature.
2.Pre-installed Mail app can not log in QQ, 163 and other mailboxes, indicating that the certificate is invalid.
3.Unable to connect to a Wi-Fi network with a hidden SSID.
4.There is a black unidentified gel at the seam between the back cover and the frame of the machine, and the gap is uneven. Some machines have problems with the speaker breaking after pressing the back cover.
5.The Xperia Home to set different lock screen wallpapers and home wallpapers, and the final wallpaper is the same.
6.The screen defaults to the default white screen for cool colors, and the look is poor. It is recommended to adjust to neutral color.
7.The Cinema Pro's viewfinder picture is not normal, there are white spots under the dark light, and the picture is dark. And some Chinese translation grammars have serious errors.
8.Slow motion recording will be stuck in 120f mode.
9.Recording and answering calls, there will be a popping sound when you first start recording or switching on.
10.The built-in phone application has been reported to stop and cannot be resolved.
We spent a lot of money to buy this phone, but we got such a "semi-finished product", and there was no sign of any repair after one week of listing. Really disappointed.
The performance of the Chinese market depends to a large extent on Sony's attitude towards Chinese consumers. If left in this way, the only loyal users will not choose your products. Don't grind it, fix it now!
Hi @Zackbuks ;
I don't have a Xperia 1 yet but I'm just trying to help, regarding point 3 I don't know if you are aware that in Android Pie the connection to a hidden SSID is a little different, when inserting the network name you have one option in advanced options that is "hidden network", you should select "Yes", have you tried it?
