My Xpeira 1 keeps dropping off my mobile data, where it comes up no internett avaible in the quick icon menu. I tried reseting it many times, and downloaded internet-setting in the internett settings. #xperia 1
same happens to me, i doubt you can fix it
I have the same issue with AT&T in the US.
let me know if you found a way to fix this
MA
Try calling your provider. I have had similar issues like this with other phones and they had to reset their "switches". Just make sure when you call in its not on the phone with the issue because they will ask you to restart the phone and preform some other tests.
Build 55.0.A.6.56
APN Nextgenphone
Thanks
MA
