Hi I got my new Xperia 1 iv. I have a question on side sense, when you open it should you see both option for recently used apps and split screen at the same time. I am thinking its in set up mode but cant see away out of it
Hi @GrumpyToad,
Why don't you have a look on this link and check the options that you can set for the side sense feature: https://helpguide.sony.net/mobile/xperia-1m4/v1/en/contents/TP0001886572.html?search=side%20sense
