The Side sense bar has disappeared on my phone since the last update.
I have checked the Side sense settings and it is definitely turned on. Does anyone have any idea how to make it reappear or is this a Sony software update issue? Thanks
Try to force restart your device and check again?
Also, try safe mode and check if it will be resolved inside safe mode or not?
