Xperia 1 ii - Sometime unable to answer and reject an incoming call and phone stays constantly ringing
This has been a problem for a while, most phone calls are answered or rejected without issue but every so often when I go to answer a call it just hangs then returns back to the incoming call screen. There's no way to get ride of it until I restart the phone.
This morning the phone had the latest 'System Update' the settings say the phone is now on Android 11 (Unsure if it was on Android 11 before the update) but the first call I received since the update had this issue.
Is this a known bug?
Hi there
Why don't you try to troubleshoot the phone app itself from the steps in this link and check if the same issue will happen or not : https://www.sony.co.uk/electronics/support/mobile-phones-tablets/articles/00235707
Wether your broblem is over or not, try Smart Call Handling.
Put the phone at your ear to answer
Shake to reject
Turn face down to silence the ringing
Great feature.
Hi
Thanks for the response, a lot of the steps in that guide I have tried before but with no luck. I've given the clearing cache for the phone app a try for now and the issue hasn't repeated yet. Although I've not had many calls and this is an intermittent issue so I'm not confident yet that that has fixed the issue. I'll check back in a month to see if the issue has repeated.
Hi rosspl2 , also try the connection during the safe mode ( Hold the power key for a secs then touch and hold on the power off option on the pop up menu )
Hope it helps!
