Hello,
I recently updated my Xperia 1 to Android 10.
Since then every time I'm in a call and put the phone on speaker it works, but when I disable speaker mode in that same call the other caller does not hear me at all.
I tried reseting the phone, activating the speaker and then disabling it in a call, it simply just doesn't work.
Anyone else had this problem and solved it?
Thank you.
Mee too same stuff
Actually you are lucky,my mic goes down when I put on speakerphone,and even when I disable that
