When wifi is disconnect form a ssid and move to b place it won't be automatically connect b place's b ssid, it need to reopen wifi.
Go into Settings - Wifi and check the saved connections.
If not you need to create or connect to the new one and enter the password, and it should save.
If they are both there, then it should auto connect as it saves created connections automatically.
I know my phone automatically jumps between my house, car/dashcam and work with no issues.
And all of those connections were created manually.
