Hi
The Xperia 5 integrates a more developed version than the Xperia 1 concerning cinema pro cinema alta, because it integrates a video editing software more complete than that provided with the Xperia 1 which is obsolete, my question is that we can to install this software on an Xperia 1?
Thanx
The Xperia 5 launched with an update to the app, and Game Enhancer, but the Xperia 1 got both of those, and since the Xperia 5 has launched, has had 2 updates to the Cinema Pro app, namely 1.1.1.A.0.6, and the latest in February/March, 1.1.1.A.0.7.
So both phones are running the updated apps.
H
Thanx for Replay, but please tell me how Can i donwload the 1.1.1.A.0.7. update ?
Thanx
Go in to your apps, then scroll down to Cinema Pro, and click Advanced, and you'll see the version no. there..
if it's 1.1.1.A.0.7 then you have the latest., you should have gotten in in the system update back in February/March.
Failing that, try apkmirror, and download it there.
I donwload it from apkmirror but when i try to install it i have this :
What version have you got on your phone.
Android version 9.0
Build 55.0.A.6.16
Version of cinema pro : 1.0.A.0.21
Wow, so no update to Android 10 then yet?
I've had about 3 updates past Android 10, uk sim free model.
Exactly I don't understand why I don't have an update!
What network are you on, and are you in the uk?
You could try to remove the sim card, and try updating over wifi, by going in to settings, system, and looking for the update.
Sometimes that works.
