Bought recently a new Xperia 1 VI and i regret to say that charging is insanely slow. It takes around two hours to charge the phone which i guess should not be the case?
Also, battery consumption is very poor (it is consumed quite fast). Is this something that can be fixed?
@c2h5oh , Try following this basic steps also make sure you're using the compatible charger with it. This article should help you with the charging tips: The art of charging
and which exact charger would you recommend for Xperia 1 VI?
thanks @Anonymous . And how much time do i need approximatly to get my Xperia 1 VI fully charged from 0%, using the one you mentioned?
@c2h5oh you can calculate the time using the article above, it could take approximately an hour.
Thank you. I will buy it and see if that works.
