I've seen an article saying the xperia 1 is able to be used on Verizon, is this true?
I would really want to buy this phone
Yes. The J8170 (US) version is the only one that will work on CDMA network.
Hi @Kc718, Let me see if I can help out here.
As @iArvee mentioned, the J8170-model is specially designed for the US market, so to my knowledge there should not be a problem using Xperia 1 with Verizon. However, I would suggest that you ask Verizon themselves to be entirely sure.
I hope that gave an answer to your question.
Hi again @Kc718,
I am sorry for being a bit vague before. I have now got confirmation that the J8170 US model is in fact Verizon network certified.
Feel free to return if you have any further questions!
I bought Xperia 1 unlocked by Amazon. My Verizon wireless contract is postpaid.
But My Xperia 1 can't receive text message.
I asked Verizon customer serviceand Sony mobile customer and I went to the Verizon shop.
But My xperia 1 couldn't receive text message.
I returned my first Xperia 1 to Amazon.
and I bought my Second Xperia 1 by Amazon.
But I have same probrem.
Xperia 1 is certified Verizon.
But My 2 new Xperia 1 unlocked couldn't receive text message.
I can send text message, call, gmail and Internet.
My new xperia 1 unlocked by amazon
model : J 8170
IMEI : 355 104 100 031 526
You have to get a new SIM card from Verizon. I was having the same issue. Just go to a VZW store, not an authorized retailer. Let them know that you need a new one.
Call into Verizon and tell them you want to activate a CDMA-less device.
I am on Verizon post paid and it works for me and they know how to do it now since they had a hiccup with Oneplus 6.
I currently have the 6T on verizon, so my sim is already provisioned cdma-less. My questions.
the j8170, is it dual sim/single sim with SD? Could i buy/use the J9110?
I do need a dual sim phone for my job, and im really looking for some feedback from users.
Thank you
J8170 is not dual sim.
J9110 is but not sure if/how it will work on Verizon since I do not think that model got "certified".
And there is no "US Warranty" on the J9110. But J9110 does get updates a few weeks earlier vs the J8170.
I just got my incoming text messages working after spending too much time on CHAT.
They needed to switch my plan to a CDMA-Less "Roam" option. That's all.
I also think the new SIM requirement is a bunch of BS.
Calls worked
Outgoing Texts worked
J8170
