Hello,
Anyone found out how can we reduce the screen to be able to use it with one hand reaching the top of a screen for example?
I use it with Gesture Navigation and not the 3 buttons (I saw that it works if I put the 3 buttons by double-clicking the center button but this is not my navigation way)
Thank you all
Go to settings, display, and scroll down to "one handed mode"
Once you enable that, you can double tap the home button to reduce the screen display size.
This option is not possible though, in gesture mode.
